Using SAM's new ground-mount slope feature with fixed-tilt PV
- Colin Schimmelfing
07 Dec 2021 15:12 #10354
by Colin Schimmelfing
Using SAM's new ground-mount slope feature with fixed-tilt PV was created by Colin Schimmelfing
Hi all,
Very excited about the new features rolling out! I am currently designing a ground-mounted system that is on a hill, and want to use the 'Terrain Slope (deg)' in combination with the GCR to get the shading losses for my system. However, if I select 'fixed tilt', then the Terrain Slope field is still grayed out.
Does anyone know how to use SAM to properly calculate shading (& therefore the ideal row spacing) with panels tilted on a slope?
08 Dec 2021 15:34 #10365
Replied by Paul Gilman on topic Using SAM's new ground-mount slope feature with fixed-tilt PV
Hi Colin,
The new terrain slope model is only available for one-axis tracking.
As you probably noticed, we did not get a chance to revise Help to add a description of the new terrain slope inputs in time for the December 2, 2021 release date. We will make that and other Help revisions for the first software update, which we expect to release sometime in February.
In the meantime, you can learn about the feature from this description and linked article on the SAM GitHub repository: github.com/NREL/SAM/pull/742
