effect of GCR on energy production
- elaheh habibi
26 Nov 2021 04:29 #10315
by elaheh habibi
effect of GCR on energy production was created by elaheh habibi
Hello, I am working with bifacial modules,
To investigate the effect of the distance between the panels on the energy produced, I changed the GCR, expecting this factor to be ineffective for very long distances because it has practically no effect on the shadow,
for example for 50 meters, and 100 meters, but the simulation results were different: 1571 For 50 meters and 1585 for 100 meters, which is problematic in two ways:
firstly, the values must be the same because the shadow is ineffective,
and secondly, considering the effect of wiring losses over long distances, the output energy should be less, not more
I appreciate your attention
29 Nov 2021 17:56 #10321
Replied by Paul Gilman on topic effect of GCR on energy production
Hi Elaheh,
Can you share the .sam file you used to generate those results with an explanation of your GCR assumptions?
SAM does not adjust wiring losses based on GCR, so you should account for that effect by changing the DC loss input.
- elaheh habibi
30 Nov 2021 14:54 - 06 Dec 2021 17:50 #10332
by elaheh habibi
Replied by elaheh habibi on topic effect of GCR on energy production
Hi Elaheh,
Last edit: 06 Dec 2021 17:50 by Paul Gilman.
- elaheh habibi
30 Nov 2021 15:13 #10333
by elaheh habibi
Hi Dear Paul,
I have sent 2 files by mistake, however, the difference in the results can be seen by GCR=0.05 and GCR=0.01 for any arrangement.
