Improving capacity factor and performance ratio
- Ahmed Mohamed
23 Nov 2021 21:23 #10311
by Ahmed Mohamed
Improving capacity factor and performance ratio was created by Ahmed Mohamed
How can one improve capacity factor and performance ratio of PV system?
Ahmed
Ahmed
29 Nov 2021 18:12 #10324
Replied by Paul Gilman on topic Improving capacity factor and performance ratio
Hi Ahmed,
There are several different ways you can improve the capacity factor and performance ratio of a photovoltaic system.
I think this might be a question for a homework assignment or test, so I am hesitant to answer it.
Please let me know if you have specific questions about how to model a potential improvement in SAM.
- Ahmed Mohamed
15 Dec 2021 19:15 #10404
by Ahmed Mohamed
Replied by Ahmed Mohamed on topic Improving capacity factor and performance ratio
Paul,
This is actually for a long-term project I am working on. See attached. I am not sure if the system components I picked are the best for this residential application or not. There are a lot of options to pick from in terms of modules and inverters. I watched the videos, and I used the optimization macros to help me pick the best system for the application. Yet, I cannot seem to improve on these two performance parameters. I would really appreciate it if you could at least point me in the right direction.
Best Regards,
Ahmed
Best Regards,
Ahmed
16 Dec 2021 09:05 #10405
Hi Ahmed,
The capacity factor and performance ratio shown in that report seem reasonable to me.
Some common ways to improve those metrics include increasing the DC-AC ratio, adjusting the array orientation (tilt, and possibly azimuth angle), and using a more efficient module and/or inverter.
There may be limits on what you can do. For example, for a roof-mounted array, you may not be able to adjust the orientation of the array, or there may be a limit on what equipment is available for your project.
