Difference between CSP concepts
- Charlie
20 Aug 2021 15:26 #9978
by Charlie
Difference between CSP concepts was created by Charlie
Dear community,
I have a somewhat basic question, but it has caused me many doubts. Mathematically I know what is the difference between "Design turbine gross ouput" and "Estimated net oput at design (nameplate)". I know the second case is less because it is multiplied by the conversion factor. But what is the difference in practice? What is the actual maximum that the plant could deliver? According to the simulation it should be the "Design turbine gross ouput", but then what is the application of knowing the "Estimated net oput at design (nameplate)", does it have any use? When an engineer says that there is a 100 MW plant to which of the two is he referring?
I would greatly appreciate if you could help me clarify these concepts please.
Kind regards
C.
Kind regards
C.
25 Aug 2021 15:22 #10003
Replied by Paul Gilman on topic Difference between CSP concepts
Hi Charlie,
SAM uses the "nameplate" capacity to calculate costs and incentives that are given in $/kW of capacity.
The "design turbine gross output" is the power cycle's maximum output under design conditions. Engineers may design a system to operate above its nameplate capacity for short periods of time.
This approach is a way to allow the system to operate at a higher capacity for a lower cost.
