Different Annual Energy for same systems
- Ricardo Ferreira
19 Aug 2021 10:02 #9971
by Ricardo Ferreira
Different Annual Energy for same systems was created by Ricardo Ferreira
I did some simulations for the exact same PV-Battery Commercial system, only changing the Electric Load scaling factor. However, the "Annual Energy (year 1)" changed between each simulation. I thought it somehow had to do with the change in the load scaling factor, but from the 3 simulations (load scaling factor of 0.1; 0.2 and 0.4), the 0.1 factor resulted in 112MWh; the 0.2 in 115MWh, the and the 0.4 in 113MWh, so it isn't a linear change. Can someone help me understand why this happens? I tried several times and the results re the same, and it affects the economics of the projects.
Ricardo
Ricardo
25 Aug 2021 09:09 #9991
Replied by Paul Gilman on topic Different Annual Energy for same systems
Hi Ricardo,
The annual energy value is the sum of the hourly or subhourly power generation values. For a behind-the-meter system with batteries, the size of the load affects how the battery is dispatched, which determines how much energy flows through the battery. Some energy is lost as the battery charges and discharges, so I would expect to see a difference in the power generation profile and annual energy for different load sizes.
