Effect of azimuth angle on annual energy production of CSP-PTC
- Weng Pin Wong
17 Aug 2021 01:15 #9955
by Weng Pin Wong
Effect of azimuth angle on annual energy production of CSP-PTC was created by Weng Pin Wong
Recently I have conducted a parametric analysis on the effect of azimuth angle on the annual energy production of CSP-PTC. I noticed that for most of the cases, the azimuth angle that can generate most energy is often in the range of -10 and 10 degree, which means that the CSP-PTC is facing south if I am not mistaken?If this is the case, then it actually suits what I found from the literature review.
However, there are some cases which oppose this finding. Those locations with the best azimuth angle out of this range are Dunhuang and Huanghe Hainan Solar Park in China. Their best azimuth angle is 70 and -19 degree. Are the best azimuth angles should be always facing 0 degree (south)? These locations are also located beyond latitude of 40 degree N, does this actually mean that further away from the equator (0 degree N), the best azimuth angle will be deviating further away from south?
Weng Pin.
Weng Pin.
17 Aug 2021 09:50 #9956
Replied by Paul Gilman on topic Effect of azimuth angle on annual energy production of CSP-PTC
Hi Weng Pin,
The optimal azimuth angle might be affected by the storage dispatch schedule or time-of-delivery PPA price multipliers that vary with time of day and year. There are different ways to define "optimal." In some situations, the optimal azimuth angle might not be zero.
- Weng Pin Wong
17 Aug 2021 21:31 #9962
by Weng Pin Wong
Replied by Weng Pin Wong on topic Effect of azimuth angle on annual energy production of CSP-PTC
Thanks for your reply!
Then if I set the annual energy production to be the desired outcome, the azimuth angle that can result in highest annual energy production might not always be 0 degree (facing south)?
Weng Pin.
Weng Pin.
18 Aug 2021 10:10 #9966
Hi Weng Pin,
Generally, I would expect an azimuth angle of zero to result in the highest annual energy production. But, in some locations, that may not be the case. For example, when there is a consistent pattern of clouds during certain times of day or year, or high mountains near the solar field.
