PV watts: standard module VS premium module
- gtqite@gmail.com
13 Aug 2021 00:24 #9930
by gtqite@gmail.com
PV watts: standard module VS premium module was created by gtqite@gmail.com
I have recently done some quick PV analysis using PV watts module in SAM (latest version) and found out the annual energy generation
difference between a standard module VS premium module is smaller than what I
would expect. See the attached screenshot.
in case you can not see it, below is the result
This is the energy output for a 1kw system as a test, I have kept all the other inputs the same, the location is LA.
Looking at the documentation from PV watts, the standard module efficiency is 15% with a -0.47%/C temperature coefficient whereas the
premium module efficiency is 19% with a temperature coefficient of power
of -0.35%/C. so I would expect the premium module would generate
0.19/0.15-1=27% more energy than the standard module. I have also checked the
web-based PV watts and it shows a similar result with SAM.
Anything I am missing? Why the premium module is marginally better. Any input is appreciated.
| standard | 1678kwh |
| premium | 1684 kwh |
16 Aug 2021 14:56 #9940
Replied by Paul Gilman on topic PV watts: standard module VS premium module
The system size in PVWatts is defined by a nameplate DC kW capacity. When you compare two systems with the same kW capacity, the module nominal efficiency would effect the size of the system rather than the system output: The system with the more efficient modules would require less roof or ground area than the system with less efficient modules.
- gtqite@gmail.com
17 Aug 2021 11:40 #9961
by gtqite@gmail.com
Replied by gtqite@gmail.com on topic PV watts: standard module VS premium module
thanks so much!
