Difference between POA reported and weather file data
- Scott Ireland
15 Jul 2021 05:21 #9829
by Scott Ireland
Difference between POA reported and weather file data was created by Scott Ireland
I am using SAM 2020.11.29 and the detailed PV calculation with default settings except for tilt angle set to zero and changing the weather data.
The "Irradiance GHI from weather file" is different to the "POA front-side irradiance total nominal (kWh/yr)" divided by the total module area as shown below.
Single values Phoenix Des Moines Fargo Blythe
Annual Energy AC (year 1) 7679.08 5572.47 5430.7 7747.59
POA front-side irradiance total nominal 48292.1 34017.8 32012.9 49319.7
POA /m2 2114.923 1489.789 1401.986 2159.926
Irradiance GHI from weather file 2115.088 1498.681 1403.705 2175.18
These values should be the same? And any difference is either down to rounding or parsing of the weather file? I note that the largest difference here is for Blythe which also had the following log notes when running:
"Calculated negative global horizontal irradiance of -3.07184 W/m2 at time [y:2009 m:2 d:1 h:17 minute:30], set to zero.
Calculated negative global horizontal irradiance of -2.94782 W/m2 at time [y:2009 m:2 d:2 h:17 minute:30], set to zero.
Calculated negative global horizontal irradiance of -2.30415 W/m2 at time [y:2009 m:2 d:4 h:17 minute:30], set to zero.
Calculated negative global horizontal irradiance of -1.02942 W/m2 at time [y:2009 m:2 d:5 h:17 minute:30], set to zero."
I am also seeing larger differences between the reported POA/m2 and the weather file data when using custom files. These also had similar log notes to the above for Blythe.
15 Jul 2021 15:55 #9830
Replied by Paul Gilman on topic Difference between POA reported and weather file data
Hi Scott,
Those small differences do seem like they could be caused by rounding.
Those warning messages tend to occur when the sun is very low on the horizon so do not have much impact on the electrical output of the system.
