Bifacial Vertical
- D
08 Jun 2021 06:34 #9680
by D
Bifacial Vertical was created by D
Hi
Does SAM have any special features for modeling bifacial photovoltaic mounted vertically (including the shadow between racks)?
Best regards
Best regards
08 Jun 2021 09:47 #9681
Replied by Paul Gilman on topic Bifacial Vertical
Hi D,
SAM's bifacial module model was developed with modules mounted on the ground or a flat roof and arranged in rows in mind, based on data from arrays with up to 45 degree tilt. SAM allows tilt angles up to 90 degrees tilt angle.
Please see Marion et al. (2017) "A Practical Irradiance Model for Bifacial PV Modules" for a description of the model that you can use to evaluate whether it will work for your application. It is listed under Irradiance, Bifacial Modules:
sam.nlr.gov/photovoltaic/pv-publications.html
