What are the thermo-physical properties of the TES materials used
- Weng Pin Wong
02 Jun 2021 03:04 #9647
by Weng Pin Wong
What are the thermo-physical properties of the TES materials used was created by Weng Pin Wong
Dear Sir/Madam,
I am recently doing a research on using different TES materials in a physical trough system. May I know where can I get these data inside the software?
Hope to hear from you soon!
Weng Pin.
Weng Pin.
03 Jun 2021 18:13 #9659
Replied by Paul Gilman on topic What are the thermo-physical properties of the TES materials used
Hi Weng Ping,
You can find information about the heat transfer fluids that SAM in SAM's Help system: See the "Solar Field" topic under CSP Parabolic Trough, Physical Trough Model. You should find a table of HTF properties and a list of data sources.
- Weng Pin Wong
05 Jun 2021 08:05 - 07 Jun 2021 10:23 #9669
by Weng Pin Wong
Replied by Weng Pin Wong on topic What are the thermo-physical properties of the TES materials used
Thanks for your reply.
Do you mean these tables in the picture below?
However, I still cannot find the thermophysical properties of the HTF like specific heat capacity, thermal conductivity, viscosity and so on. Since these properties are varying with the temperature across the literature review, I hope to know the values of these properties used in the SAM simulation. Are these values available in the software?
Weng Pin.
Weng Pin.
Last edit: 07 Jun 2021 10:23 by Paul Gilman.
07 Jun 2021 10:43 #9673
Hi Weng Ping,
See my response in this thread for a link to an Excel file with the fluid properties:
sam.nlr.gov/forum/forum-general/42
