Doubt NSRDB data
- Pão Man
07 May 2021 12:54 #9558
by Pão Man
Doubt NSRDB data was created by Pão Man
Hello, I was downloading some weather files directly from SAM in advanced mode, and the time zone was wrong in some (value 0), in Brazil it is -3.
I realized then that in the simulation the curve was approximately -3h shifted. Can I fix this when downloading or just editing the CSV?
Are all data downloaded by SAM from satellites? Is there a recommendation for simulate batteries, if I can really trust the intermittency of these curves? I always used POA bases, but now I need another location.
The file name has latitude, longitude, and "full disc" (-25.4284_-49.2733_full-disc_60_2019.csv).
Another thing, this displacement will only interfere in the graph of the curve, the simulation result I think is the same. Right?
Thanks in advance to everyone for your help
07 May 2021 17:01 #9562
Replied by Paul Gilman on topic Doubt NSRDB data
Hi Pão,
Some of the downloads from the Advanced NSRDB Download window return files with data in UTC instead of local time.
We have fixed that problem for SAM 2020.11.29 r2, which we hope to release next week: github.com/NREL/SAM/issues/605
In the meantime, you can fix that by editing the file and changing the time zone to the local time zone, and also shifting the data by the appropriate number of hours. You could copy the appropriate number of hours from the beginning of the file to the end since those are nighttime hours and will not affect the solar resource data. If you do that, be sure to shift only the data, not the time stamps (Year, Month, Day, Hour, Minute).
