Some problems with the parametric simulation
- Weng Pin Wong
28 Apr 2021 01:33 #9534
by Weng Pin Wong
Some problems with the parametric simulation was created by Weng Pin Wong
Recently when I want to simulate the LCOE for different combinations of TES storage hours and solar multiple using parametric simulation, it shows that the LCOE will change with the storage hours but not with solar multiple.
However, when I go back to the system design panel and change the solar multiple values, the final LCOE did have changes, is there any solution to this issue?
Thanks.
Weng Pin.
Thanks.
Weng Pin.
03 May 2021 11:49 - 03 May 2021 11:51 #9544
Replied by Paul Gilman on topic Some problems with the parametric simulation
Hi Weng Pin,
For the Physical Trough model, you should use the specified_solar_multiple variable for parametric simulations instead of solar_mult.
Also, be sure to choose Option 1 on the System Design page.
Last edit: 03 May 2021 11:51 by Paul Gilman.
