Negative electric power
- Francisco
17 Apr 2021 15:46 #9472
by Francisco
Negative electric power was created by Francisco
Dear community,
I am simulating a CSP plant with central tower technology. When I get the results, there are certain hours that I have a negative generation. What would be the physical explanation for that? How is it possible to have a generation less than 0? I would really appreciate if you help me understand it. I am attaching an image to make it a little clearer.
Thank you very much in advance,
Francisco
Francisco
19 Apr 2021 10:57 #9479
Replied by Paul Gilman on topic Negative electric power
Hi Francisco,
Negative power indicates that the system is consuming more power than it generates. In the case of a CSP power tower system, SAM models parasitic loads for electric pumps and heaters that circulate and heat the HTF at night to prevent it from freezing.
- Francisco
19 Apr 2021 14:08 #9480
by Francisco
Replied by Francisco on topic Negative electric power
Thank you very much for your kind reply Paul. One last question please. I think that in previous versions of SAM, for CSP technology it was possible to define the "Storage Distpach" (w / solar or w / o solar). Currently that is not possible anymore? Now I only have Turb. ouput fraction. Or maybe I'm looking wrong.
Francisco
Francisco
19 Apr 2021 16:19 #9482
Hi Francisco,
As of SAM 2020.2.29, the Physical Trough model uses a new dispatch control algorithm in place of the old manually controlled method. See the Help topic for the System Control page for a description of the algorithm. It is also described in Wagner M (2018) "Optimized Dispatch in a First-principles Concentrating Solar Power Production Model" available under "Power Tower" on the CSP publications page: sam.nlr.gov/concentrating-solar-power/csp-publications.html .
If you have a reason to use a model with the old dispatch method, you can download SAM 2018.11.11.
