Doubt about the use of POA or DNI/GHI
- Pão Man
09 Apr 2021 07:49 #9441
by Pão Man
Doubt about the use of POA or DNI/GHI was created by Pão Man
Dear, I did simulations with real POA data and it worked. Now I have to test another location where I have data from the DNI / GHI Solarimetric station. I have an NSRDB database from the same location. Which option is best for my use:
1 - Can I put the GHI data in the POA field and simulate it? Would that be correct? I'm simulating PV power plants with trackers. But, these data are horizontal. Will SAM adjust?
2 - Or, put the DNI/GHI/DHI and other data from that physical station into the NSRDB? So, I will not select the POA option.
I always use the NSRDB base of the site and replace the CSV data to have a CSV model as a reference.
Thanks.
Thanks.
09 Apr 2021 15:11 #9443
Replied by Paul Gilman on topic Doubt about the use of POA or DNI/GHI
Hi Pão,
If you have measured GHI and DNI data, then you can put those in the GHI and DNI columns of your weather file. If you inserting your data into a file from the NSRDB (or any other source), you could rename the original GHI and DNI column headings so that SAM's weather file reader can correctly interpret the data. For example you could change the column heading "GHI" to "NSRDB GHI" so the reader will ignore that column.
Also, in SAM, on the Location and Resource page, be sure to change the Weather File Irradiance Data option under Albedo - Sky Diffuse Model - Irradiance Data (Advanced) to DNI and GHI.
