clearance height
- cüneyt erken
24 Mar 2021 17:49 #9394
by cüneyt erken
clearance height was created by cüneyt erken
I'm working on bifacial pv power plant, project gcr is 0,506 and row spacing estimate is 3,95 m, if i activate the bifacial specification button and give clearance height 1 m, row spacing estimate again 3,95 m. I think row spacing estimate should be greater than 3,95. Can you explain the situation.
Best regards.
Best regards.
25 Mar 2021 17:50 #9397
Replied by Paul Gilman on topic clearance height
Hi Cüneyt,
The ground clearance height is an input parameter for the bifacial model to determine how much sunlight reflects from the ground to the back of the module. It does not affect the row spacing estimate, which SAM calculates as:
Row spacing (m) = Length of Side (m) / GCR
