Subarray 1 Short circuit Current (A) is not computing properly
- Miles Russell
12 Mar 2021 12:05 #9368
by Miles Russell
Subarray 1 Short circuit Current (A) is not computing properly was created by Miles Russell
I don’t think that “Subarray 1 Short circuit DC current (A)” in the Lifetime Hourly Data is calculating correctly. It appears to be the
current for a single source circuit (or individual PV module) and NOT the subarray as defined on the System Design tab. Please check that.
12 Mar 2021 17:35 #9369
Replied by Paul Gilman on topic Subarray 1 Short circuit Current (A) is not computing properly
Hi Miles,
Thank you for the feedback.
That label is incorrect. It is the short circuit current (Isc) of a single string in Subarray 1 rather than of the subarray Isc. You can calculate the subarray Isc by multiplying the "Subarray Isc" by the number of strings in the subarray.
I have create an issue on our GitHub repository for this so we can fix it: github.com/NREL/SAM/issues/562
Would you mind telling us how you are using this value? What would be the best value for SAM to report?
