Mass flowrate in IPH model
- fayya
25 Jan 2021 06:13 #9231
by fayya
Mass flowrate in IPH model was created by fayya
Hello Dear,
I would like to know how does SAM calculates "heat sink HTF mass flowrate" for the IPH model, because I have remarked certain discrepancies between what I estimate manually and what SAM estimates. Thank you for your support and reply.
25 Jan 2021 17:49 #9232
Replied by Paul Gilman on topic Mass flowrate in IPH model
Hi Fayya,
The IPH Trough model uses the same model for the trough system as the Physical Trough model, so you can use the Physical Trough model publications posted here for reference:
sam.nlr.gov/concentrating-solar-power/csp-publications.html
These other discussions on the forum may be helpful:
sam.nlr.gov/forum/forum-general/1760
sam.nlr.gov/forum/forum-general/3099
- fayya
10 Feb 2021 04:24 #9273
by fayya
Replied by fayya on topic Mass flowrate in IPH model
Thank you for your reply. Yes, I have already examined the available documents and papers of the Physical Trough model since it is the model used for IPH Trough.
Nevertheless, while examining hourly results for thermal heat sink and mass flowrate at heat sink (which is eventually HTF mass flowrate in the boiler of the power block), I have noticed that mass flowrate deviates a lot from its design value, which can be calculated through an enthalpic balance: flowrate = heat_sink / ( (Tf-Tin)*Cp), I couldn't figure out the reasons for these deviations.
