Suneye shading effects in 2012.11.30
- Vijaykrishna
10 Dec 2012 16:44 #1073
by Vijaykrishna
Suneye shading effects in 2012.11.30 was created by Vijaykrishna
Hello this question is regarding the new SAM version (2012.11.30) The Question is as follows:
- I am trying to understand the effect of shading at a location using the SunEye Hourly Shading file in Michigan. However there seems to be no difference in energy output(kWh) with or without enabling the hourly shading option(with data). I did not have to do anything else in the previous versions. I am missing anything?
I have attahed the.zsam file and the Suneye hourly shading file(.csv)
Thanks for your Help.
Vijay
Vijay
14 Dec 2012 09:04 #1074
Replied by Paul Gilman on topic Suneye shading effects in 2012.11.30
Dear Vijay,
Thank you for pointing out this issue. We are investigating it now, but it looks like the PV models' hourly beam shading matrix table (1 x 8,760) may not be working correctly in SAM 2012.11.30. I will post an update as soon as I have more details.
- Vijaykrishna
20 Dec 2012 14:20 #1075
by Vijaykrishna
Replied by Vijaykrishna on topic Suneye shading effects in 2012.11.30
Thank you for confirming this. Please let me know if i could do anything else.
Regards
Vijay
Regards
Vijay
20 Dec 2012 17:08 #1076
Dear Vijay,
As a workaround until the January update, you can use Subarray 2 to import the Suneye shading data. On the PV Subarrays page, enable Subarray 2, and set the number of strings allocated to subarray 2 equal to the total number of strings in the array. That will cause the number of strings allocated to Subarray 1 to be zero. Click Edit Shading for Subarray 2, and import your Suneye shading data. (This models your system as a single array, but uses the Subarray 2 inputs to describe it instead of the Subarray 1 inputs. The issue with shading data only applies to Subarray 1)
