Issues with "Electricity to battery from System" and "Electricity to/from grid "
- Vinoth Mannan Muruganandam
26 Dec 2020 23:17 #9138
by Vinoth Mannan Muruganandam
Issues with "Electricity to battery from System" and "Electricity to/from grid " was created by Vinoth Mannan Muruganandam
Hi There,
I had simulated a Detailed PV Battery Behind the metersystem.
The dispatch algorithm was set to be manual for 4 hours inthe night.
The rest of the hours was set to charging. The charging & discharging from the grid is disabled.
As pert the dispatch algorithm, the battery dischargescorrectly.
However, for charging, I do understand that the default algorithm supports the load first and the excess
is used to charge the battery.
a) However, the simulation numbers show that the excess after the load is completely exported to the grid. (The battery charging
power is not subtracted in the excess to the grid).
PGrid = PSolar – Pload and not PGrid = PSolar – Pload -Pbatt
(Attached excel: Cell 34)
b) The battery is also being charged even if the excess after load is not enough to charge the battery.
Numbers reflect that the battery is charged to the maximum Charging power even if ( PSolar – Pload < PMax Charging Power) (Attached excel: Cell 35)
Hence the “Electricity to battery from system” and the “Electricityto/from grid” doesn’t reflect the correct numbers.
Would appreciate if someone can comment and help me on this.
Thanks.
Vinoth
Thanks.
Vinoth
09 Apr 2021 15:00 - 09 Apr 2021 15:00 #9442
Replied by Paul Gilman on topic Issues with "Electricity to battery from System" and "Electricity to/from grid "
Hi Vinoth,
Sorry about not responding to this. Somehow this post slipped away from me.
Could you attach orThis email address is being protected from spambots. You need JavaScript enabled to view it. a copy of the file that generated these results?
Could you attach or
Last edit: 09 Apr 2021 15:00 by Paul Gilman.
