Hourly simulation in CSP Trough Physical technology
- Nora Eisam
03 Dec 2012 04:10 #1042
by Nora Eisam
Hourly simulation in CSP Trough Physical technology was created by Nora Eisam
Good morning,
In the data tables, when you select the hourly simulation of any parameter SAM shows the value of this parameter each hour (0 h, 1 h, 2h...). The shown value is the average calculated for a period of time:
What is exactly this period of time for each row of the table?
For example:
The solar field thermal output that is in the row of 7 pm, it has been calculated from 6.30 to 7.30, or from 6 to 7?
thanks in advance
For example:
thanks in advance
03 Dec 2012 15:20 #1043
Replied by Paul Gilman on topic Hourly simulation in CSP Trough Physical technology
Please see the explanation in SAM's Help system:
Weather Data Overview under Time Convention and Sun Position
- Nora Eisam
04 Dec 2012 07:26 #1044
by Nora Eisam
Replied by Nora Eisam on topic Hourly simulation in CSP Trough Physical technology
Thanks a lot, but i have read this document and it's not very clear.
For example, in the hour 7 SAM chooses:
- Solar angle and incident angle at 6.30
- The wind speed, ambient temperature, and humidity values at 7
Is that correct?
Best regards
Is that correct?
Best regards
04 Dec 2012 14:26 #1045
Hi Nora,
That is correct for one of the TMY files from the National Solar Radiation Database: The weather file contains a single set of values for the hour 7. The solar angle values in that hour represent the sun's position at 6:30. The solar radiation values are the total radiation over the hour that ends at 7. The wind speed, ambient temperature, and humidity values are instantaneous values at 7.
