Simulating thermosyphon based solar water heating
- Nitish Kanetkar
08 Oct 2020 02:29 #8827
by Nitish Kanetkar
Simulating thermosyphon based solar water heating was created by Nitish Kanetkar
Is it possible to simulate thermosyhon based solar water heating in sAM?
08 Oct 2020 13:50 #8830
Replied by Paul Gilman on topic Simulating thermosyphon based solar water heating
Hi Nitish,
Please see the description of the solar water heating model in SAM's Help system and the references on the SAM website at sam.nlr.gov/solar-water-heating.html for information about the model.
- Nitish Kanetkar
09 Oct 2020 05:10 #8841
by Nitish Kanetkar
Replied by Nitish Kanetkar on topic Simulating thermosyphon based solar water heating
Thank you for the response.
In SAM's solar water heating model it is required to key in the water flow rate through the collector, which means it is a forced system where the water/glycol is pushed through the collector for heat transport. Is there an option in SAM where the water flow rate through the collector is coupled to the heat received from the solar radiation?
Nitish
Nitish
09 Oct 2020 14:59 #8846
Hi Nitish,
No, there is not an option for that type of collector.
