Shading Error in PV + Battery system
- Afroz Khan
07 Oct 2020 01:55 #8822
by Afroz Khan
Shading Error in PV + Battery system was created by Afroz Khan
Hi there
I have a PV system with a battery and I keep getting the following error: exec fail(pvsamv1): Error calculating shading factor for subarray 0 at index 0.
I did not change anything under shading, I've left all values as default. I've seen a previous post about this and the error was in the weather file. I have checked the weather file and there are no errors with it. This error also started occurring on previous SAM PV models where I had no errors before.
It was suggested to me to try and use a previous version of SAM where I did not have this problem. The latest previous version available is the 2018 version, which I've installed. But now I cannot open any of my models as it was saved on the 2020 version.
How can I fix this? Is there a way to open files saved on the 2020 version in the 2018 version? Is there a new 2020 version coming out soon that fixes this problem?
Kind Regards
Afroz Khan
Kind Regards
Afroz Khan
08 Oct 2020 17:28 #8834
Replied by Paul Gilman on topic Shading Error in PV + Battery system
Dear Afroz,
Please see this post for a workaround solution to this problem:
sam.nlr.gov/forum/forum-general/3095
- Afroz Khan
09 Oct 2020 01:24 #8837
by Afroz Khan
Replied by Afroz Khan on topic Shading Error in PV + Battery system
Hi Paul
I have already seen this solution. I did follow the step-by-step procedure but it does not change the error. My weather file does not seem to be my issue.
I've also used that same weather file in a CSP model and it works with no error.
Is there any way to download any of the previous 2020 versions of SAM? The most recent download allowed by the website is the 2018 version and not any of the previous 2020 versions. As I mentioned, my model worked perfectly before. It only occurred when I updated my SAM. I'm not sure if it may be a problem with SAM for Southern Hemisphere models.
Kind Regards
Afroz
Kind Regards
Afroz
- Afroz Khan
09 Oct 2020 04:39 #8840
by Afroz Khan
Hi Paul
I had seen this post and tried to fix the weather file but it did not work. I do believe that there is an error with the weather file, though it used to work before.
Its source is ISD-TMYx and was obtained from a source recommended by NREL. This weather file used to work, it is only since I've updated SAM that it does not work.
I'm not sure how to fix the weather file.
Kind Regards
Afroz Khan
Kind Regards
Afroz Khan
09 Oct 2020 15:02 #8847
Hi Afroz,
We are working to fix this issue: github.com/NREL/SAM/issues/365 .
Would you mind attaching a copy of your .sam file and the .epw file so we can use it it to test?
- Afroz Khan
10 Oct 2020 08:01 #8850
by Afroz Khan
Thanks Paul.
I've attached the files below. ]
