Bi-Directional Inverter for Battery systems
- Vikram Linga
13 Aug 2020 15:17 #8574
by Vikram Linga
Replied by Vikram Linga on topic Bi-Directional Inverter for Battery systems
Paul,
I have already set the options as you have said, and I am not seeing an impact on any metric when I switch from "No Electricity Rate" to "Enable Electricity Rate".
Vikram
Vikram
13 Aug 2020 16:28 #8577
Replied by Paul Gilman on topic Bi-Directional Inverter for Battery systems
Hi Vikram,
Can you attach a .sam file that shows this behavior?
- Vikram Linga
16 Aug 2020 21:12 #8590
by Vikram Linga
Paul,
Attached is a SAM file containing two models:
The electricity rate, when enabled, is set at its default of 0.06 $/kWh. Both systems give the same summary metrics as far as I can see (mainly looked at NPV and checked a couple others), when the electricity rate is enabled and when it is disabled. As discussed, I believe this is an error because the NPV should be higher when the electricity rate is enabled since it is lower than the PPA price.Please let me know if I am missing something here. Thanks again I appreciate the help.
Vikram
- "Detailed PV-Battery, PPA Single owner" (150 MWac PV, 50 MWac/ 200 MWh storage)
- "Generic System-Battery, PPA Single Owner" used for Standalone storage (50 MWac/ 200 MWh)
Vikram
- Vikram Linga
16 Aug 2020 21:16 #8591
by Vikram Linga
Paul,
Just making sure the previous attachment was correct. It should be the same as this attachment, but if not please use this one you will see it is the systems described int he previous post. Also I am using SAM version 2020.2.29.
Vikram
Vikram
17 Aug 2020 10:24 #8592
Hi Vikram,
Thank you for sending the files with detailed descriptions.
I think this may be a bug -- it looks like SAM is using the Buy Rate on the Electricity Rates page to calculate an electricity purchase amount for grid power used to charge the battery as an annual operating expense even when you choose No Electricity Rate on the Electricity Rates page. You can verify the issue by looking at the "Electricity purchase ($)" line item on the Cash Flow tab, and also by going to the Data Tables tab, and displaying the annual "Annual energy imported from grid (kWh)" and "Electricity purchase ($)" variables. (Note that both inflation and the electricity bill escalation rate apply to the electricity purchases.)
In the meantime, a workaround for a front-of-meter storage system (PV Battery or Generic System Battery with one of the PPA financial models models) if you want to treat electricity purchases for charging the battery as negative revenue:
- On the Electricity Rates page, choose Enable Electricity Rate (from the blue drop-down list at the top of the page) so you can see the rate structure.
- Choose the Buy all / sell all metering option.
- Set the Buy Rate to zero.
- Choose No Electricity Rate.
- Vikram Linga
17 Aug 2020 12:09 #8598
by Vikram Linga
Thank you Paul.
Another question I had was with the Merchant PV-Storage option. I am not able to generate revenue using this model using the "single value" revenue mode.
I know there have been previous posts about this, such as: sam.nlr.gov/forum/forum-general/3068-merchant-plant-generating-revenue.html#8442
Has this issue been fixed? And if so should the "single value" option be working?
