How to increase sub arrays to more than 4 in SAM tool
- Darren
12 Aug 2020 15:07 - 12 Aug 2020 17:39 #8549
by Darren
How to increase sub arrays to more than 4 in SAM tool was created by Darren
Good day,
I am currently working on a model and we may require more than 4 sub arrays in the shading screen. Please advise if this can be increased in the tool?
Last edit: 12 Aug 2020 17:39 by Paul Gilman.
12 Aug 2020 17:43 - 18 May 2023 09:35 #8556
Replied by Paul Gilman on topic How to increase sub arrays to more than 4 in SAM tool
Hi Darren,
For SAM's Detailed Photovoltaic model, each case in SAM supports up to four subarrays, so it is not possible to define shading scenarios for more than four subarrays.
Depending on the system you are modeling, you may be able to use the Combine Cases macro to represent the system, as described in this post: sam.nlr.gov/forum/forum-general/1540 .
The image you posted did not upload properly. If you would like to include it in a reply, please attach it as a file using the Attachments button (you can then insert it into your message) rather than pasting it into the editor.
Last edit: 18 May 2023 09:35 by Paul Gilman.
