Battery augmentation strategy
- Luana
22 Jul 2020 10:03 #8471
by Luana
Battery augmentation strategy was created by Luana
Dear
I would like to know if it is possible to do a battery augmentation capacity strategy instead of replacing the entire battery in SAM. For example adding more battery capacity in some specific years.
Thank you
Thank you
22 Jul 2020 11:55 #8472
Replied by Paul Gilman on topic Battery augmentation strategy
Hi Luana,
For now, it is not possible to change the system design over time, so no, it is not possible to add battery capacity when the battery is replaced.
Can you describe more about the scenario you would like to model?
- Luana
23 Jul 2020 03:02 #8479
by Luana
Replied by Luana on topic Battery augmentation strategy
Hello, thank you for the answer.
Actually I was trying to replicate a case in SAM of this paper: www.sciencedirect.com/science/article/abs/pii/S0306261919321531
In the case of the paper, they talk about augmentation capacity and not about replacement. As I was trying to replicate the case, I looked for this option in SAM. Or when they do the "battery augmentation", is it a specific case of replacement in SAM?
Thank you
Regards
Luana
Thank you
Regards
Luana
23 Jul 2020 12:28 #8481
Hi Luana,
Thank you for the explanation. The authors in that paper use the term "augmentation" to mean that rather than replacing the entire battery bank when its capacity degrades below a certain storage capacity, the system owner would add batteries to the bank.
To model that kind scenario in SAM 2020.2.29, choose the Replace at specified schedule option under "Battery Replacements" on the Battery Storage page. For Battery bank replacement schedule, click Edit array and enter a 1 in the row for each year you would like the battery to be replaced (Row 1 is for Year 1). Then, for Battery bank replacement percent, enter the percentage of the battery's original installed capacity required to achieve the desired "augmented" capacity in each of those years.
Be sure to also define the battery replacement cost on the System Costs page under "Operation and Maintenance Costs."
- Jawwad Aga
13 Oct 2022 04:33 - 13 Oct 2022 15:11 #11572
by Jawwad Aga
Replied by Jawwad Aga on topic Battery augmentation strategy
Last edit: 13 Oct 2022 15:11 by Paul Gilman.
13 Oct 2022 15:19 #11574
Hi Jawwad Aga,
Please attach a sample Python script (and any supporting files) that demonstrates the results you are seeing if you would like me to help troubleshoot.
