Solar Thermal Industrial Process Steam
- Mark Weeks
14 Nov 2012 16:35 #1010
by Mark Weeks
Solar Thermal Industrial Process Steam was created by Mark Weeks
Can SAM model industrial process steam generation from solar thermal technologies? It appears that the Concentrating Solar Power models focus on electricity generation and the Solar Water Heating models are geared toward relatively low temperature domestic hot water. However, it would seem as though the Concentrating Solar Power models could be used to determine collector field heat output which could be used to estimate industrial process steam generation. Alternatively, an equivalency factor could be used to convert kWh back to steam generation in mmBtu. Is this possible?
16 Nov 2012 10:42 #1011
Replied by Paul Gilman on topic Solar Thermal Industrial Process Steam
Hi Mark,
Both of the approaches you describe are possible. Because SAM assumes that solar field energy is being used to drive a power block for electricity generation, it makes some assumptions about how to control the field to maintain HTF flow and temperature based on the power block requirements that may be different for a process steam application.
Here are a couple of threads on this topic:
Solar Process Heating
Using SAM to Model Steam Production
