power and process heat co-generation CSP solar plant for power and desalination
- HassanKM
25 Jun 2020 16:59 #8359
by HassanKM
power and process heat co-generation CSP solar plant for power and desalination was created by HassanKM
I want to study different scenarios for solar thermal desalination. Usually, thermal desalination systems extracting low-pressure steam from the power plant's turbine to operate the desalination system in a co-generation scheme.
Another scenario to compare is to use direct steam from the CSP-heat system to operate the thermal desalination systems.
I cannot find the page to specify the steam extraction conditions in the power cycle. Also, how the Levelized cost of this steam can be evaluated?
Thank you for your support.
26 Jun 2020 15:43 - 26 Jun 2020 15:44 #8361
Replied by Paul Gilman on topic power and process heat co-generation CSP solar plant for power and desalination
Hi Hassan,
SAM's Industrial Process Heat (IPH) models calculate a "levelized cost of heat" They assume that the field heat transfer fluid (HTF) is delivered to a heat exchanger that collects heat for the application. You can use the time series output of the solar field (output variables with names that begin with "Field..." to determine properties of the HTF.
For more, see the IPH video here:
sam.nlr.gov/concentrating-solar-power/csp-videos.html
and, publication listed here:
sam.nlr.gov/concentrating-solar-power/csp-publications.html
Last edit: 26 Jun 2020 15:44 by Paul Gilman.
