How to input parameters in molten salt CSP model
25 Jun 2020 11:49 #8357
Replied by Paul Gilman on topic How to input parameters in molten salt CSP model
Hi Francesca,
One optimization solution is not necessarily more acceptable than another, so you will have to make a judgement and choose a solution. Using the same initial values may result in a different solution for different runs. I'm not sure changing the initial values to the previous optimizations optimal values will help.
We do hope to improve the algorithm in the future to make it more robust, but do not have plans to do so in the immediate future.
- Francesca
27 Jun 2020 11:54 - 29 Jun 2020 12:45 #8363
by Francesca
Replied by Francesca on topic How to input parameters in molten salt CSP model
Here is my another simulation,
My initial values are : Tower height = 203.33m, Receiver height = 20.41m, Receiver diameter = 17.67m.
After I optimized the layout of heliostats, New values are: Tower height = 133.816m, Receiver height = 10.8271m, Receiver diameter = 7.88733m, Heliostats reflective area = 88060 m2 . I accepted the updates of this layout.
In the same file, based on this updated layout (The number of heliostats and tower height, receiver height etc are already changed), I choose to optimize the layout again: Then the value became: Tower height = 63.8577m, Receiver height = 8.50437m, Receiver diameter = 4.89721m, Heliostats reflective area = 94613 m2 .
So in this case, the tower height and receiver geometry are quite different. Then if i optimize the layout based on a already optimized result, is this acceptable or I should only optimize it once?
Francesca
Francesca
Last edit: 29 Jun 2020 12:45 by Paul Gilman.
