Battery Efficiencies
- Nayeli
18 Jun 2020 09:10 #8325
by Nayeli
Replied by Nayeli on topic Battery Efficiencies
Thanks for your reply, Paul. I have built a customized model of a Li-ion battery and have the same issue (more energy discharged than charged). I tried using the custom Li-ion option and also using LFP and simply editing some of the inputs to eliminate degradation, for example. The problem persists in both cases.
18 Jun 2020 10:27 #8327
Replied by Paul Gilman on topic Battery Efficiencies
Hi Nayeli,
Would you mind attaching a copy of a .sam file that demonstrates the issue with the Li-ion battery and/or LPF?
- Nayeli
19 Jun 2020 04:44 #8329
by Nayeli
Yes, I am attaching the file here. The last two tabs are the cases that I mention where I tried to customize the Li-ion model to resemble a vanadium redox flow battery but get more energy discharged than charged.
Nayeli
Nayeli
- Paul McPherson
25 Jun 2020 02:55 #8355
by Paul McPherson
Replied by Paul McPherson on topic Battery Efficiencies
The conversion to use a Li-Po battery sounds good, I'll give it a try and will give some feedback once I can provide some!
