SAM to MATLAB code errors (Generic System and Battery)
- Giorgos S. Georgiou
26 Mar 2020 11:18 #8069
by Giorgos S. Georgiou
SAM to MATLAB code errors (Generic System and Battery) was created by Giorgos S. Georgiou
Hi
I converted SAM to MATLAB code and when I run the code I get the following errors:
generic_system errors:
fail(system_use_lifetime_output, integer): number could not be interpreted as an integer: 5.26354e-315
I changed the "system_use_lifetime_output" parameter from 1 to 0 for overcoming this error.
battery errors:
fail(batt_replacement_option, integer): number could not be interpreted as an integer: 5.26354e-315
I changed the "batt_replacement_option" parameter from 1 to 0 for overcoming this error.
battery errors:
exec fail(battery): Generic System must be AC connected to battery.
I don't know how to overcome the above. Could you help me please?
battery errors:
battery errors:
12 May 2020 09:42 - 12 May 2020 09:54 #8184
Replied by Paul Gilman on topic SAM to MATLAB code errors (Generic System and Battery)
Hi Giorgos,
It looks like integer values of zero are being generated as very small decimal values, which may be causing errors. You may need to go through and change those values to zeros. We are working to resolve that issue as described here:
sam.nlr.gov/forum/forum-sdk/2949
For Generic Battery configurations, you should verify that system_use_lifetime_output = 1 and batt_ac_or_dc = 1.
Last edit: 12 May 2020 09:54 by Paul Gilman.
