Error in SHW simulation
- granthawkins88
22 Oct 2012 10:53 #975
by granthawkins88
Error in SHW simulation was created by granthawkins88
I'm attempting to run a simulation for a flat-plate solar thermal collector system.
- I'm new to SAM, though I have lots of experience in solar design and modelling
- I'm using a user-input module
- I'm only interested in technical outputs
Attempting to run the simulation, I get the following error message:
SAMSIM MESSAGES
MSG[1]: SVAL LOOKUP ERROR trnsys.user_exe
MSG[2]: SVAL LOOKUP ERROR trnsys.user_args
*** An error has forced TRNSYS to abort
Can anyone tell me, based on this error, what I'm missing/doing wrong?
Thank you all!
SAMSIM MESSAGES
Thank you all!
24 Oct 2012 11:21 #976
Replied by Paul Gilman on topic Error in SHW simulation
Would you mind replying with a copy of your .zsam file as an attachment, or emailing it via the Contact form .
What weather file did you use for the simulation? A problem with the data in the weather file can cause this kind of error.
