Rates for demand charges in the Dominican Rrepublic
- Carlos Liquet
02 Mar 2020 18:58 - 13 Mar 2020 10:19 #8019
by Carlos Liquet
Rates for demand charges in the Dominican Rrepublic was created by Carlos Liquet
In my country for residential and commercial building for peak demand up to 10 kW the demand charge is $0; however for peak demand beyond 10 kW the charge ($/kW) is calculated based on the average of the two months with the highest peak, then all sub-sequence months throughout that year will be charged with this fixed value. See file attached for illustration. Question, How may I setup this method in "Rates for demand charges" section?
Best Regards,
Carlos
Best Regards,
Carlos
Last edit: 13 Mar 2020 10:19 by Paul Gilman.
13 Mar 2020 10:29 #8038
Replied by Paul Gilman on topic Rates for demand charges in the Dominican Rrepublic
Dear Carlos,
I think you could approximate this structure for demand charges as follows:
1. Run a simulation with no demand charges to identify the two months with the highest peak and calculate the average $/kW rate.
2. Enable demand charges, and set the tiered demand charge rate using the average value you calculated for $/kW.
3. Run a simulation with demand charge to calculate the electricity bill savings.
- Carlos Liquet
13 Mar 2020 13:12 #8040
by Carlos Liquet
Replied by Carlos Liquet on topic Rates for demand charges in the Dominican Rrepublic
Thanks Paul for your help on this!
Carlos
Carlos
