Help with Calibration
- saman1368
12 Feb 2020 09:48 #7969
by saman1368
Help with Calibration was created by saman1368
I am trying to calibrate my model to the actual data, in order to do that i need 2019 and 2020 Solar radiation data but SAM database only have up to 2018, is there any solution to that? please advice
Regards
Amir
Regards
Amir
12 Feb 2020 09:58 #7970
Replied by Paul Gilman on topic Help with Calibration
Dear Amir,
The NREL National Solar Radiation Database (NSRDB) is updated each year to add the previous year's data. If you need data for years or locations not covered by the NSRDB, you can try one of the other sources of data listed on the SAM website:
sam.nlr.gov/weather-data
- saman1368
12 Feb 2020 11:49 #7975
by saman1368
Replied by saman1368 on topic Help with Calibration
I was able to download data that include Snow depth, is there any template that I can use to generate .csv spreadsheet data that will be readable with SAM?
12 Feb 2020 16:53 #7977
Hi Amir,
Please see the SAM CSV weather file format description in SAM's Help system. You can find it in the table of contents under "Weather Data, Weather File Formats."
You can also find examples of files in the SAM CSV format in your SAM installation folder in the solar_resource folder as described here:
sam.nlr.gov/forum/forum-general/2776-sam-installation-folder.html
