Wind speed measurements at only 10 m height
- Isabel
06 Feb 2020 08:26 #7954
by Isabel
Wind speed measurements at only 10 m height was created by Isabel
Hello everybody,
I want to do a wind study in order to get the power that can be generated in a certain localisation. I have data from measurements taken by a company working for us, but this measurements are only taken at 10 m height.
SAM does not let me to place wind turbine hub at a height that differs more than 35 m with the measurement data.
I thought about using a fluid mechanics equation, however I would like to know if there is a better way to do it. Does SAM has a method for this?
Thank you very much, I really appreciate your time taken to answer this.
Best Regards,
Isabel España Boronat
Best Regards,
10 Feb 2020 10:23 #7962
Replied by Paul Gilman on topic Wind speed measurements at only 10 m height
Hi Isabel,
SAM's wind power model does not have tools for adjusting the wind speed data in your weather file. You could use a method like those described here:
websites.pmc.ucsc.edu/~jnoble/wind/extrap/
