LEAC and Energy Rates on Guam
28 Jan 2020 17:21 - 28 Jan 2020 17:30 #7910
Replied by Paul Gilman on topic LEAC and Energy Rates on Guam
Hi Rob,
A compiled executable for SDKtool comes with the SAM desktop application when you install SAM. You can find it in the linux_64 folder SAM installation folder, which, on Linux, might be something like:
Note that you can load different versions of the SSC library into SDKtool, which is useful for comparing input and output variables of different modules across different versions.
Please see the SDK page on this website for more on working with the SDK, including where to find documentation for SDKtool:
sam.nlr.gov/software-development-kit-sdk.html
home/SAM/2018.11.11/linux_64
Last edit: 28 Jan 2020 17:30 by Paul Gilman.
- Rob Frohne
28 Jan 2020 20:39 #7913
by Rob Frohne
Replied by Rob Frohne on topic LEAC and Energy Rates on Guam
Wow! Thanks Paul!
Rob
Rob
- Rob Frohne
29 Jan 2020 00:49 #7917
by Rob Frohne
Thanks Paul,
The issue was that somewhere in the docs I saw that on linux it was all lower case "sdktool". I don't know where that was, but on the page you cite above, it is SDKtool, and just where you said it was.
Thanks!
Rob
Thanks!
Rob
- Rob Frohne
29 Jan 2020 01:41 #7918
by Rob Frohne
I'm contemplating your suggestion for implementing the changing rate structure. Here are my thoughts. I'd love your critique.
Rob
- I load the .json file inputs from SAM exports.
- I run pvwatts7, and transfer the output from that to utilityrate5.
- I run utilityrate5 once per year, with a ur_ec_tou_mat modified with the rate data for each year. I multiply the system_of_use_lifetime_output by (1-degredation)^n, where n, an element of {0, 1, ... N-1}, is the year I'm simulating for the nth year. (Similar for the load_escallation, if I use it.) I save all the outputs for each yearly simulation.
- I haven't figured out how to integrate those inputs as an input to cashloan yet, but hopefully that will be possible.
Rob
29 Jan 2020 17:43 #7919
Hi Rob,
That sounds like a reasonable approach, although I'm not sure what system_of_use_lifetime_output is. I think you mean that you'll apply the annual degradation rate to the values in the time series (hourly or subhourly) array for the system output to account for degradation, which makes sense.
I fixed a couple of those references to "sdktool" instead of "SDKtool" and tried to make it clear that it's in the linux_64 folder in some revisions I made yesterday.
- Rob Frohne
29 Jan 2020 21:33 #7922
by Rob Frohne
The beta version SDKtool doesn't seem to come with the 2020.1.14 beta, so that might confuse people too.
Thanks for all the assistance!
Rob
Rob
