Discounting An Existing Solar System in Detailed PV with Storage
- hhundt
12 Nov 2019 11:15 #7784
by hhundt
Discounting An Existing Solar System in Detailed PV with Storage was created by hhundt
Hi Paul and forum group,
I've read in few areas on the Forum that SAM does not yet allow for using the existing PV system with its production data along with the load of the building that has the PV and modeling the addition of storage.
A few solutions I have come up with to try and discount the existing system while modeling on addition PV and first-time storage. I was wondering if you saw any issues with these approaches, which one seems the most accurate and if they seemed within bounds of SAM's logic. I am asking because I coming up with very different results. Note: this is a zero energy building scenario so we are working in negative returns at the moment because of net metering rules where we are.
1. Estimate native load by removing the impact of existing PV. Model as a complete new system, with existing PV represented in the total new capacity. Add in a CBI value on year 0 that is equal to what the existing PV is worth. Concerns: the cash "incentive" is being overvalued somehow in a 25yr analysis.
2. Take actual load that has the impact of existing PV (with some 15 min values reach negative because of peak summer production), adding in additional PV, storage and running. Concerns: SAM seems some days with a negative grid load but doesn't see the potential to capture that energy with the battery. It only sees the impact of new PV.
3. Model storage only (add in a tiny PV system as place holder--a few kW) with actual building load that has the impact of PV left in. Take results and combine with a PV only run of additional solar. Concerns: same issue as above.
Hopefully this makes sense. Would be happy to share files if you would like. Thanks for your time,
Henry
Henry
13 Nov 2019 09:00 #7788
Replied by Paul Gilman on topic Discounting An Existing Solar System in Detailed PV with Storage
Hi Henry,
I"m not sure I understand your question exactly, but I'll try to provide some information that might be helpful.
SAM's Residential and Commercial financial models determine the value of the PV or PV-Battery system by comparing the electricity bill with the system to the electricity bill without the system. SAM reports the monthly electricity bill "with system" and "without system" so that you can see the effect of the system on the electricity bill. The "energy value" line item in the cash flow is the difference between the annual "without system" bill and "with system" bill.
In SAM, the "load" is the building's electricity consumption. It does not change with the addition of PV or battery to the building. The amount of electricity the building uses from the gird changes, but the load does not. You can see the amount of electricity that comes from the grid, PV system, and battery to meet the load in the time series results.
If you want to model the addition of batteries to an existing PV system, you could set the PV module and inverter direct capital costs on the System Costs page to zero.
- hhundt
13 Nov 2019 09:44 #7790
by hhundt
Replied by hhundt on topic Discounting An Existing Solar System in Detailed PV with Storage
Thanks for your note-as usual very helpful and timely. Thanks so much!
A few clarifying items from my question and how I will be interpreting your response.
The facility I am looking at already has PV on it. I created a load profile for the facility from utility and solar 15 min data, which I am calling "native load" because, as you noted, it removes any excess generation back to the grid giving a picture of the facility's actual energy use. I am using this "native load" to model the existing PV (78kW) with an additional 280kW along with storage, or in another scenario, just storage in various financial arrangements. I want to model all the PV not just new arrays so that the battery controller knows what solar resources are available at each timestep.
My main question, which you seemed to have gotten to, is how to discount the cost for the existing PV on the financial side for the various setups. My concern was that because there is diminishing marginal value of the PV as the system output outpaces what the facility needs (in hopes of reaching zero energy), that I might need to be careful where and how I discount the existing PV costs.
For the scenario which only sees us adding a battery, I will do as you say and just set capital costs of a PV system that match what is already on site to zero. For scenarios where I add PV, I will discount capital costs (rate per installed watt) that represent what is already onsite.
Thanks again.
Best,
Henry
Thanks again.
Best,
Henry
- hhundt
21 Jan 2020 10:42 #7888
by hhundt
Coming back to an older question and post. I am still wrestling with how best to model financials of adding storage to existing PV.
If I run as suggested above and set the direct capital cost of PV to 0 (sized to represent what is already existing at the site), isn't the model assuming that you're getting all the kWh from the PV with no cost, and thus skewing NPV's and cashflow? If SAM is looking at cost with/without system, then wouldn't it always be skewed towards storage?
Thanks for your time.
24 Jan 2020 16:04 #7896
Hi Henry,
The "with/without system" cost is the electricity bill with and without the system, which is different from the cost of installing and operating the system.
The electricity bill is determined from the inputs on the Electricity Rates and Electric Load inputs page. The installation and operating cost is determined from the inputs on the System Costs page.
Setting the installation cost of PV to zero will remove the cost of installing the PV system components from the Year 0 cost in the project cash flow, but it will not affect the annual cost savings in the cash flow, which is the difference between the electricity bill with and without the system.
