SWM File format help
- sbarsun
03 Oct 2012 16:12 #923
by sbarsun
SWM File format help was created by sbarsun
I'm trying to get a pre-processed weather file in SWM format to read into SAM. Is there an example SWM formatted file anywhere?
Copying these lines from the manual into a .csv or .swm doesn't work;
723860,"Clark/El Dorado",NV,-8.0,35.796245,-114.974334,548.64,3600.,2010,0:30:00
5.15,-4.7,-999.,46.4225,0.65,295.0,941.97,0.0,0.016517,0.0,0.23,-999.
3.85,-4.1,-999.,54.1635,0.35,245.0,944.99,0.0,0.008,0.0,0.23,-999.
2.95,-3.85,-999.,58.752,0.3,225.0,945.785,0.0,0.08555,0.0,0.23,-999.
What am I missing? If I have a similar file with 8760 lines it still gives the 'Invalid Weather file, check data in line 1' error.
Stephan
Stephan
04 Oct 2012 10:18 #924
Replied by Paul Gilman on topic SWM File format help
Hi Stephan,
You can see an example of an SMW weather file (NW EL Deorado Hourly.smw) in your SAM installation's weather file folder, which by default in Windows is:
C:\SAM\2012.5.11\exelib\climate_files
In SAM 2012.5.11, only the Flat Plate PV and Physical Trough models can read SMW files.
Based on my tests, it seems that to run with the Physical Trough model, each row in the SMW file must end in a comma. The commas do not appear to be required for the Flat Plate PV model.
- sbarsun
05 Oct 2012 14:22 #925
by sbarsun
Replied by sbarsun on topic SWM File format help
Thanks much for the quick response. It seems that the PVWatts Simplified Model works with (or at least will read) SWM files in the 2012.9.27 BETA version. Is this planned functionality or does is it just appearing to work?
Stephan
Stephan
08 Oct 2012 10:23 #926
Hi Stephan,
That is by design. We are gradually porting the code for all of SAM's performance models to a new simulation platform. Among many other things, the new platform allows for reading weather data in the SMW format. In the Beta and Fall 2012 versions, the PVWatts model runs on the new platform, and so can read the SMW files.
