Stochastic analysis
- emiliano casati
12 Aug 2019 02:52 #7608
by emiliano casati
Stochastic analysis was created by emiliano casati
Dear all,
I find the "stochastic capabilities" of SAM are very interesting and I'd like to present these to my students. However, I was not able to find a proper manual documenting them. I just found a recent post with short video-tutorials .
Beside setting input and output, which is quite straightforward, there are unclear things:
Emiliano
- what is the "enable weather file analysis" option doing?
- there are calculated figures, likely regression results, named "Delta R^2" and "Beta" (calculated for each uncertain input variable). What is the definition of these quantities?
Emiliano
26 Aug 2019 17:09 - 26 Aug 2019 17:10 #7630
Replied by Paul Gilman on topic Stochastic analysis
Hi Emiliano,
The "enable weather file analysis" option requires a folder containing set of weather files. When you enable the option, instead of creating a set of values for an input variable, it creates a set of weather files chosen from the files you provide, and then runs simulations using those files to calculate the distribution parameters for results variables you choose. For example, you could use this technique to determine a statistical range of values for annual energy or net present value based on the variation in a series of weather files over multiple years.
You can see what it does by clicking Compute samples to generate an example distribution of weather files. However, this table does not match the table SAM uses for the actual stochastic simulations when you click Run simulations, and unfortunately, the table of results does not show you the computed samples that SAM used for the simulations. This is a known issue that we will address by adding a right-click tool that shows you a table of computed samples used to calculate the results, but that feature will not be available until the fall 2019 version in a couple of months.
Last edit: 26 Aug 2019 17:10 by Paul Gilman.
- emiliano casati
17 Dec 2019 05:32 #7845
by emiliano casati
Replied by emiliano casati on topic Stochastic analysis
Dear Dr Gilman,
thanks for your precise feedback about my first point!
Could you please give me some info on the second point of my question?
Thanks in advance
Emiliano
Thanks in advance
Emiliano
19 Dec 2019 16:42 #7847
Hi Emiliano,
SAM's stochastic simulations use the Sandia Latin Hypercube Sampling (LHS) package. The references for that package are provided in the SAM Help system:
SAM uses the Sandia Latin Hypercube Sampling (LHS) package ( dakota.sandia.gov/content/packages/lhs ) to calculate statistical distributions for stochastic simulations. The LHS sampling method is described in Wyss, G; Jorgensen, K. (1998). "A user's Guide To LHS: Sandia's Latin Hypercube Sampling Software." Sandia National Laboratories. SAND98-0210. 140 pp. ( PDF 559 KB ) For a more general discussion of sampling-based uncertainty analysis, see Helton, J.; Davis, F.; (2000). "Sampling-Based Methods for Uncertainty and Sensitivity Analysis." SAND99-2240. 121 pp. ( PDF 5 MB ) For a basic description of the Latin hypercube sampling method, see the Wikipedia article " Latin hypercube sampling ."
The PDF documents describe the different distribution inputs, but don't seem to describe those regression outputs, and, unfortunately I don't have specific documentation for those.
