PVWatts calculation of solar zenith (and sun above horizon variable)
- craigl33
05 Aug 2019 11:13 #7595
by craigl33
PVWatts calculation of solar zenith (and sun above horizon variable) was created by craigl33
Hi all
I'm wondering if anyone knows how SAM (or more specifically PVWatts/detailed solar module) is calculating the solar zentih/sun above horizon variable. This seems to be causing issues when running with ERA5 data that has been put into the SAM CSV format.
I am unsure if it relates to a) the input time-zone, b) lat/lon and/or c) datetime index. Basically, I am inputting in local time but the solar zenith (according to the detailed PV module) is completely off. I have tried changing the UTC time, but it seems to have issues.The problem is that the solar position is completely wrong in addition to the output being clipped by the 'Sun above the horizon' variable.
Any help in understanding the interaction of these different variables would be greatly appreciated.
Craig
Craig
06 Aug 2019 16:10 #7600
Replied by Paul Gilman on topic PVWatts calculation of solar zenith (and sun above horizon variable)
Hi Craig,
The Detailed Photovoltaic model sun angle equations are described in Section 4.2 the SAM photovoltaic reference manual, which you can download from the PV Publications page of the SAM website.
- craigl33
07 Aug 2019 02:41 #7602
by craigl33
Replied by craigl33 on topic PVWatts calculation of solar zenith (and sun above horizon variable)
Hi Paul
Many thanks for this reference. It is very helpful. I was getting quite confused with the sun-up variable being a non-binary flag, which now is explained.
I would also like to applaud those who are responsible for the new PySAM module. This is a fantastic piece of work which has made many aspects of the SAM workflow so much easier, quicker and more manageable!
Craig
Craig
