solar elevation and azimuth angles for PV systems
- Zigurts Majumdar
25 Jul 2019 09:43 #7576
by Zigurts Majumdar
solar elevation and azimuth angles for PV systems was created by Zigurts Majumdar
I was comparing results results using SAM and PV_Lib (from the Sandia PVPMC website) PV systems and found some inconsistencies. Some of this appears due to the fact that for a given location (same weather file, TMY3 data file) the solar elevation and azimuth angles can differ by up to about 8 degrees (I am ignoring the "-999" entries for now). I am surprised it is that big. I used both the ephemeris algorithm and the NREL solar position algorithm in PV_Lib and both agree to well under 1 degree. This is causing the angle of incidence to the PV panel and consequently the plane of array irradiance to be off when comparing modeling between SAM and PV_Lib.
I wanted to find out how these angles are being calculated in SAM and whether they have been compared with the algorithms I am using in PV_Lib.
Ziggy
Ziggy
31 Jul 2019 08:48 #7584
Replied by Paul Gilman on topic solar elevation and azimuth angles for PV systems
Hi Ziggy,
SAM's Detailed Photovoltaic model uses the Mikalsky (1988) algorithm for the sun position calculations. We hope to switch to the NREL SPA algorithm , and to make the SAM's sun position calculations for all of SAM's solar models consistent as described here:
github.com/NREL/ssc/issues/279
The Photovoltaic Reference Manual listed on the PV Publications page describes the PV model's sun position equations:
sam.nlr.gov/photovoltaic/pv-sub-page-2.html
