Unresolvable NaN error in the heat loss calculations
- Michael Smith
03 Jul 2019 08:10 - 05 Jul 2019 16:01 #7500
by Michael Smith
Unresolvable NaN error in the heat loss calculations was created by Michael Smith
When I run the attached model using the attached weather file (from energyplus.net/weather ), I get the error "unresolvable NaN error in the heat loss calculations". However, I don't get this error using the default weather files in the SAM solar resource folder. The following are my questions:
1. Can you check if the format of the attached weather file is accurate?
2. Are there any templates, which follow the required order of rows/columns in the weather data, for different file types (TM2, SRW, EPW, CSV, DDY, STAT, etc) ?
Last edit: 05 Jul 2019 16:01 by Michael Smith.
03 Jul 2019 09:18 - 03 Jul 2019 09:19 #7502
Replied by Paul Gilman on topic Unresolvable NaN error in the heat loss calculations
Hi Michael,
The format of the EPW file you attached is fine, but there may be a problem with the atmospheric pressure values in the file. You can use a couple of SAM macros to confirm that (click Macros under the Simulate button):
The SAM CSV format is described in SAM's Help system, under Weather Data, Weather File Formats.
SAM's CSP models generate a simulation warning if there is a problem with a calculation in each time step. If there are only a handful of warnings for the 8,760 hourly time steps, you can usually ignore them.
- The "Solar Resource File Checker" macro works with files in the SAM CSV, EPW and the old TMY2 and TMY3 file formats and runs some checks on the data to help identify problems.
- The "Solar Resource File Converter" macro converts files from EPW, old TMY2 and TMY3, SolarAnywhere, PVsyst CSV and PVGIS V5 CSV formats to the SAM CSV format, which can be a little easier to work with than the other formats.
Last edit: 03 Jul 2019 09:19 by Paul Gilman.
- Michael Smith
03 Jul 2019 10:06 #7508
by Michael Smith
Replied by Michael Smith on topic Unresolvable NaN error in the heat loss calculations
Thanks for your reply. The EPW weather file (attached to my 1st post and downloaded from energyplus.net/weather) is the same as the weather file used for the case using SAM 2013.1.15 in your website. Can you explain why the atmospheric pressure hourly values "DO NOT" affect the model results in SAM 2013.1.15 but "DO" affect the results in SAM 2018.11.11 ?
Michael
Michael
03 Jul 2019 11:01 #7510
Hi Michael,
We made some changes to the Physical Trough model in SAM 2018.11.11 SSC 198 that are listed in the SAM release notes under that version name that involved pressure calculations.
I'll ask the CSP model developers if they can provide any additional insight.
