Solar Tower System-Heliostat numbers
- vp16
10 Sep 2012 06:51 #825
by vp16
Solar Tower System-Heliostat numbers was created by vp16
I am trying to model a Solar Tower System using SAM for my curiosity and knowledge purpose.
I am stuck with the numbers of heliostat in the system, I input all the variables known and then click on the optimization wizard, but it does not give the number of heliostats as known beforehand by the project details.
I know the actual number of heliostats and the area occupied, but since SAM calculates on its own, I could not move ahead. Could somebody please guide me on the same at the earliest.
Thank you.
Thank you.
10 Sep 2012 11:59 #826
Replied by Paul Gilman on topic Solar Tower System-Heliostat numbers
To model a power tower with a known number of heliostats, you can use the table at the bottom of the Heliostat Field page to specify the number and location of heliostats.
An alternative approach if you do not have information about the distribution of the heliostats in the field is to run the optimization with different parameters until the wizard calculates a number of heliostats close to the number you want to model. For example, you can adjust the maximum tower height to see how it affects the number of heliostats.
- vp16
13 Sep 2012 01:24 #827
by vp16
Replied by vp16 on topic Solar Tower System-Heliostat numbers
I do not have the distribution because it is not published by the company, and I also know the tower height, so with all these parameters known, I cannot get the desired number of heliostats. I tried changing the parameters but then it reduces even more the number of heliostats.
Please suggest something as my probelm is stuck in the same place since last week.!! Many Thanks.!!
13 Sep 2012 11:32 #828
Can you describe what you are trying to do? It sound like you want to use SAM to model an existing system. What information do you have about the system? Are you trying to estimate how much electricity the system will generate?
- vp16
14 Sep 2012 08:45 #829
by vp16
Actually I want to apply it for a hypothetical 50 MW plant for MS Tower which a fellow student designed in his thesis and I am trying to make a sensitivity analysis in SAM with electricity generation and LEC and other details.
However I also tried verifying some results for an existing plant but as said I was stuck with the heliostat numbers and hence the total reflective area and the associated costs with it changed due to difference in numbers. So I did not go on with the analysis of existing plant.
However, yesterday while I was trying to solve the Optimisation Wizard generated a number and then I also edited the table below with some random numbers of helistats so that I can get the desired number.
I am not aware how this would affect ma analysis if I try to modify the number generated by the wizard.
14 Sep 2012 09:35 #830
The power tower model's field optimization wizard's purpose is to help you find the number and distribution of heliostats, tower height, receiver height, and receiver diameter that minimizes the system's levelized cost of energy given the other performance, cost, and financial parameters that you specify. It makes sense to review the wizards results and change them as necessary before running simulations.
If you do change a parameter like the number of heliostats after running the wizard, the system you simulate may not be the lowest cost system.
