Error in running tornado chart
- abelapur
06 May 2019 07:14 #6778
by abelapur
Error in running tornado chart was created by abelapur
While creating a tornado chart with input variable as the energy charge TOU matrix, I get an error "Error with input variable: Energy charge TOU matrix. Must be a number."
Where exactly in the model is it expecting a numeric input?
I have run the simulation for multiple commercial and residential rates and I'm getting this error every time.
06 May 2019 09:45 #6779
Replied by Paul Gilman on topic Error in running tornado chart
The "Energy charge TOU rate matrix" input is a two-dimensional array of numbers. The Create a Tornado Chart macro only works with inputs that are numbers.
It is not possible to generate a tornado chart using the macro for an value that is part of an array. For example, the buy rate is part of an array that defines the rate structure for energy charges, so it is not possible to generate a tornado chart for the buy rate unless you modify the code in the macro.
SAM's macro are written in the LK scripting language. The following LK code snippet extracts the buy rate from the energy charge matrix:
x = get('ur_ec_tou_mat');
for( i=0; i<#x; i++ )
buy_rate[i] = x[i][4];
