Unreliable grid
- selfa
06 Apr 2019 00:52 #6735
by selfa
Unreliable grid was created by selfa
1.Can SAM model unreliable grid. If yes how?
2. what assumptions do I need to do for me to model off-grid PV system in SAM
08 Apr 2019 12:26 #6736
Replied by Paul Gilman on topic Unreliable grid
SAM does not have explicit inputs for modeling an unreliable grid. SAM assumes that the system can always deliver power to the grid, but you could use the "Availability and Curtailment" inputs to model grid outages as periods when the system output is curtailed.
SAM does not model off-grid systems.
- Javier H Narvaez
20 Feb 2020 19:27 #7991
by Javier H Narvaez
Replied by Javier H Narvaez on topic Unreliable grid
Ok. I understand that SAM does not model off-grid systems, but if the battery bank is great enough for not need to import from grid, why always there is a little value for energy from grid, no matter how great is the size of batteries?
Thanks in advance for helping to interpret this kind of results.
Javier H.
Javier H.
21 Feb 2020 14:05 #7992
Dear Javier,
The inverter nighttime consumption may be responsible for that small amount of grid power. You can verify that using the "Inverter night time loss" variable.
- Javier H Narvaez
21 Feb 2020 14:59 #7995
by Javier H Narvaez
I think so, but this night consumption couldn't be covered from the bank of batteries (In SAM), seeking the goal of reducing to zero the imports from grid?
Thank you Paul.
Javier H.
Thank you Paul.
Javier H.
