Rated Cycle Convertion Efficiency Vs Turbine Efficiency
- sidom
18 Jul 2012 03:58 #717
by sidom
Rated Cycle Convertion Efficiency Vs Turbine Efficiency was created by sidom
SAM input data request Rated Cycle Convertion Efficiency. Turbine Manufacturers provide in their Heat Balance values for Turbine Efficiency (or Heat Rate). How can we relate one value into the other? What losses/parameter relate one to another?
How does SAM (Physical Model) consider conversion efficiencies at partial loads?
Thanks a lot.
Thanks a lot.
19 Jul 2012 14:07 #718
Replied by Paul Gilman on topic Rated Cycle Convertion Efficiency Vs Turbine Efficiency
Please see Chapter 3 The Power Cycle of the
physical trough reference manual
for a description of how the physical trough model represents the power cycle.
- sidom
23 Jul 2012 11:01 #719
by sidom
Replied by sidom on topic Rated Cycle Convertion Efficiency Vs Turbine Efficiency
Does SAM take into consideration efficiency losses in heat exchangers in "Rated cycle conversion efficiency" parameter? Is this parameter the efficiency of the whole power block?
Thanks and regards
Thanks and regards
