Parametric inputs/outputs corrupted
- shanek123
08 Mar 2019 11:09 #6672
by shanek123
Parametric inputs/outputs corrupted was created by shanek123
HI,
All inputs and outputs tabs for parametric analysis and stoch' analysis seem to be corrupted (see image), my version of SAM is up to date. any ideas why they are all looking like this?
Thanks.
Thanks.
11 Mar 2019 11:48 #6673
Replied by Paul Gilman on topic Parametric inputs/outputs corrupted
Your screenshot looks normal to me. Can you tell me what trouble you are having?
Note that the list of variables in the Select Inputs window shows several pieces of information about the variable. For example for the first variable listed in your screenshot, "AC wiring" is the variable label, and "acwiring_loss" is the variable name. The units are "%" and the variable type is "number."
Please see the short video about how to run parametric simulations from this Parametric and Statistical Analysis webinars:
sam.nlr.gov/node/69276
Older versions of SAM only showed the variable name, so the list in the video will look a little different than in SAM 2018.11.11, but the procedure is the same.
