A (probably unrealistic) wish
- mreimer
04 Feb 2019 08:48 #6639
by mreimer
A (probably unrealistic) wish was created by mreimer
It would be super interesting to have a "reality-check" mode where SAM could take actual daily weather/albedo/air mass/etc. measurements, starting from when a system is put into production, run them through the model, and compare to its predictions using TMY to see how a system might be over- or underperforming.
Matt
Matt
04 Feb 2019 11:27 #6640
Replied by Paul Gilman on topic A (probably unrealistic) wish
Dear Matt,
If you have measured weather and solar irradiance data for a project, it is possible to use it in SAM to make a comparison like the one you describe.
Also, you can download "single year" weather files over the range of 1998-2017 from the NREL National Solar Radiation Database in addition to the typical meteorological year (TMY) files. That makes it possible to compare results from a TMY file to results from a specific year. See sam.nlr.gov/weather for more about using weather data in SAM.
