Can I modify a cell temperature model equation
- Ramanan C J
22 Jun 2026 09:08 #14573
by Ramanan C J
Replied by Ramanan C J on topic Can I modify a cell temperature model equation
NOCT type mathematical model for predicting solar PV cell temperature in floating photovoltaic systems is now available.
www.linkedin.com/posts/activity-7467494042705088512-5aKj
doi.org/10.1016/j.solener.2026.114731
22 Jun 2026 11:10 #14574
Replied by Paul Gilman on topic Can I modify a cell temperature model equation
It is not possible to set or modify the cell temperature calculated by SAM's Detailed Photovoltaic model using the desktop SAM application. It is possible to choose different options to adjust parameters of the cell temperature model using the inputs under "Temperature Correction" on SAM's Module input page. You could also make adjustments to the ambient temperature data in the weather file.
It is possible to set the cell temperature using the subarray[n]_custom_cell_temp_array input variable if you are using PySAM or running the SSC module directly.
Please see this issue on GitHub.com for further details: github.com/NatLabRockies/SAM/issues/106 .
