Can I modify a cell temperature model equation
- bpm77
04 Jan 2019 17:37 #6587
by bpm77
Can I modify a cell temperature model equation was created by bpm77
Hello Paul,
I'm trying to use SAM to model a floating PV system and I wanted to change the equation SAM uses to calculate cell temperature. The equation found in the literature is rather simple and considers ambient temperature, irradiance and wind speed something between the lines of tcell = a*ambient temperature + b*irradiance + c*wind speed.
Is there a way to modify the way it is calculated to a user input equation?
Thanks for the support,
Bruno
Bruno
04 Jan 2019 20:10 #6588
Replied by Paul Gilman on topic Can I modify a cell temperature model equation
Dear Bruno,
It is not possible to modify the equation SAM's photovoltaic models calculate cell temperature. The different module models offer different cell temperature calculation options.
We are making some changes to the structure of the photovoltaic models that may make it possible to define a custom equation in the future, so I've added your request to a related one on the SAM GitHub Issues list:
github.com/NREL/SAM/issues/106
- Adriane Dave Teves
11 May 2021 03:52 #9583
by Adriane Dave Teves
Replied by Adriane Dave Teves on topic Can I modify a cell temperature model equation
May I know an update on this concern? Thank you!
11 May 2021 09:01 #9584
Hi Adriane,
We are not actively working on this issue at the moment.
SAM is an open source software project, so it would be possible to build your own version of SAM and modify the cell temperature calculations. You can find build instructions on the SAM GitHub repository's wiki: github.com/NREL/SAM/wiki .
24 May 2021 05:05 #9619
Thank you for the quick response!
- FC
13 Aug 2021 23:34 #9933
by FC
Replied by FC on topic Can I modify a cell temperature model equation
It may be possible to simulate Floating Solar PV in SAM if cell temperatures could be modified or offset in SAM.
Procedures for modifying some of the parameters for floating solar in PVlib or PVsyst are described herein:
Sustainability Assessment Framework and Methodology with Trans-disciplinary Numerical Simulation Model for Analytical Floatovoltaic Energy System Planning Assessments
www.researchgate.net/publication/353718769_Sustainability_Assessment_Framework_and_Methodology_with_Trans-disciplinary_Numerical_Simulation_Model_for_Analytical_Floatovoltaic_Energy_System_Planning_Assessments
