Trouble selecting weather Data
- J. Velázquez
27 Nov 2018 15:54 #6520
by J. Velázquez
Trouble selecting weather Data was created by J. Velázquez
When i try to select a weather data file (that i used in the past version of SAM) the program starts changind data and it closes right away. ¿How can i fix this issue?
27 Nov 2018 16:07 #6521
Replied by Paul Gilman on topic Trouble selecting weather Data
Would you mind attaching a copy of the weather file that causes this problem to your post above, or emailing it to me ?
29 Nov 2018 10:26 #6522
Thank you for providing the files that caused the problem.
There is an issue in SAM 2018.11.11 with the CSP models that we will resolve in the next software update.
In the meantime, please replace the
file in your SAM installation folder (
) by default in Windows) with this updated one:
raw.githubusercontent.com/NREL/SAM/patch/deploy/runtime/ui/Solar%20Resource%20Data.txt
runtime/ui/Solar Resource Data.txt
C:/SAM/2018.11.11
06 Dec 2018 11:03 #6523
SAM 2018.11.11 Revision 1 should resolve both of these issues.
If you modified the
according to my instructions above, you may need to download and install a new version of SAM instead of updating the original version:
sam.nlr.gov/download
Please try installing a clean version and let me know whether or not that works.
If you modified the
